Mach Discussion => General Mach Discussion => Topic started by: ballistic42 on December 20, 2015, 03:32:39 PM
Hello I am trying to learn how to make a DRO for one that does not exist. I am using MachScreen and know how to make a DRO that is a standard code or OEM code but not one that I have created. I want a set a number in my Tool Up DRO so that I know how High my Z axis is for my tool change. Any help would be awesome. Would it be made via a brain or VB? And yes for the macro this distance is the distance that the tool is before the Carousel slide can retract.
Jeff
HIYA Jeff I would love to help BUT I have never heard of what you are describing you need. Can you describe how your Tool changer works as to the motions required. A picture or drawing would be nice OR if you have seen an example of what you need on youtube ??
TP, Thanks for the reply. With trying multiple things and reading more on VB Scripting I was able to figure it out. It works the way I want it to now. In a nutshell here is what I was trying to do. I made a label saying Tool Up Position, next to that I have a DRO. What I am trying to see on the screen is the Tool Up Position for when the ATC carousel can slide into the extend area for the tool change. At that point the Z axis will come down and pickup the tool, that being the Tool Down Position for the Z. I added a button next to the DRO that says (Tool Up Position). I can now click on the button and the DRO will indicate the Tool Up Position. I am ready to take it a step further and make the button move the Zaxis upto that Tool Up Position so that I could do a manual tool change for when I implement my touch screen. I am really making my ATC screen look similar to one I found on the net that I like with a few mods of my own.
I hope it all works like I have planned.
Jeff
