Support => Forum suggestions and report forum problems. => Topic started by: machining fool on December 05, 2015, 07:26:22 AM
What is the difference of the blocks preceding my post. One says "you posted here" and another says " normal post", what is the difference? Bob.
Hi Bob,
If you created the thread then it may say 'Normal Post'
If you reply to a thread you did not create then it will say 'You Posted Here'
If the reply's to a thread (if you created it or not) exceed a pre-determined number then it will say 'Hot Thread'
There are other variants as well, they are basically all designed to help you navigate the forum and make it a more enjoyable experience. ;)
Thenk you, I thought I was being blackballed or something. I created all of the posts that say, "you posted here", so that is why I asked. I thank you for your quick answer. Bob..........................................................................................
