Mach Discussion => General Mach Discussion => Topic started by: originator on March 08, 2006, 01:29:43 AM
I have a system that runs fine with MAXNC 10 CLB software, but will not budge with MACH3. I have selected the MAX Cl mode which is supposed to set the pinouts automatically according to the video tutorial. In MAXNC port setup it shows the port as being 000-27F and works fine. In the config in MACH3, no matter what I type in it says 200-27F.
If anyone can give a suggesion that would be great. The factory said good luck. Their software will get by but it is dos type stuff, no mouse and very crude.
I I don't know anything about the MaxNC wave drives... Is this a wave drive? I think there are a few guys on the group running the Max CN Mills.
Art will know what you need to do when he gets back in a few days.
thank you
Brian
I think there is a version that is open loop that is wave, this one is closed loop and the MACH 3 has a button for the CL. Hopefully someone has some experience with the combo.
