Mach Discussion => Mach4 General Discussion => Topic started by: Cbyrdtopper on October 27, 2015, 10:58:50 AM
I want to do some testing with Mach4. I have a VMC that I use for maintenance and custom work that has Mach3. Can I put Mach4 on this machine using the same ESS board and go between Mach3 and Mach4 freely?
-Chad
To be honest I cant see any problems at all.
DazTheGas
I've had both working on the same machine for year and a half and that is using all 6 axis's. But just in testing Mach4 only. Still don't have the full trust to let it loose on a big job to be able to walk away (as some of my runs last days). Runs smoother but has some hiccups at times.
Running ESS on the PMDX-126 board using 2 Servos(Slaved), 2 Nema-34 & 2 Nema-23 Steppers
Okay, thanks Ya-Nvr-No. I've got the ESS on this machine so gonna give it a go and see what happens.
