Mach Discussion => General Mach Discussion => Topic started by: finyl vinyl on October 21, 2015, 03:24:11 PM
hi, I am very new to Mach3 and CNC router, I have purchased a table top system and have down loaded mach3 I have gone through set up (twice actually as I uninstalled and started again) however I have a problem:
The DRO works perfectly whilst jogging however the table etc does not respond
I have watched the 3 videos on u tube and ensured that all appears correct, any ideas, my only thought is that the series cable is faulty?
Any ideas gratefully recieved
Paul
Are you using the parallel port? If so, what operating system?
Sounds like you have the wrong port address, a bad cable, or an OS that Mach3 won't work on (64 bit)?
Thanks Gerry, I have checked port address? I have 32 bit machine and can check a new cable tomorrow morning
I also gave an issue in the diagnostic screen in that the LEDs flash with the table turned on or off, is this possiblely related also?
Sorry to be needy but I am very frustrated
Regards
Paul
