Mach Discussion => Mach4 General Discussion => Mach4 Videos => Topic started by: DazTheGas on October 05, 2015, 03:48:53 PM
Well still on the quest of making my custom copy of mach4 I needed a more indepth tooltable, I wanted to be able to select a tool from a library and mach4 load all the params I needed.
for Instance I use the mdi panel a lot and do a fair bit of by eye milling so If I decide I want to change tool then mach will change all the spindlespeed - feedrates etc for me.
So I created this for a start and can develop further as needed.
And of course you can have a copy too. ;)
The Script is Here http://www.machsupport.com/forum/index.php/topic,30973.0.html (http://www.machsupport.com/forum/index.php/topic,30973.0.html)
The Setup and Usage Video Here https://youtu.be/qxKroGC5a1M (https://youtu.be/qxKroGC5a1M)
DazTheGas
