Third party software and hardware support forums. => Mach3 and G-Rex => Topic started by: haroutkhaloian on October 02, 2015, 06:35:50 AM
helllo
if you could help me with my problem that would be great .. i have a little problem with mach3 vb script .. whenever i write this vb script it sends a message says "syntax error" is there anything wrong in the script ... im a newbie here ( the script is for Mach3 probe that works with THC proma ) and if you have good probe scripts that works with THC that would be great if you sent them
the script:
CurrentFeed = GetOemDRO(818)
PierceHight = -4.0
ProbeFeed = 1300.0
Code "G90 F" &ProbeFeed
If GetOemLed(825)=0 Then
Code "G31 Z-117 F" &ProbeFeed
While IsMoving()
Wend
Code "G4 P0.25"
ZprobePos = GetVar(2002)
Message "ProbePos is" & ZprobePos
Code "G0 Z" &ZprobePos
While IsMoving()
Wend
Call SetDRO(2. PierceHight)
While IsMoving()
Wend
Code "G4 P0.6"
Code "G0 Z 0"
Code "G92 Z0.0"
Message "Z at Perice Hight " & ZprobePos
Code "F" & CurrentFeed
StartTHC()
ZeroTHC()
Else
Code "(ERROR. Plate is Grounded)"
GotoSafeZ()
Exit Sub
End If
if you could help me please reply soon
