Mach Discussion => General Mach Discussion => Topic started by: BIGWING on September 06, 2015, 07:57:09 AM
I am in the process of setting up my lathe tool turret
I am using small stepper motor, an encoder and using Pokeys 57E
I have a button via Pokeys calling a macro controlling the operation.
In the macro I have G01 code controlling the movement with a high
feed rate F900. I need this high a feed rate because of the turret gearing
It all works as expected except when I first load up mach and try it
at this point it appears to use the feed rate in feed DRO.
It completes the cycle ok but way to slow.
Once it has completed one cycle it seems to follow the macro perfectly.
Does anyone have any ideas on what could be influencing the first cycle
Any ideas would be greatly appreciated
cheers George
Can you post the macro?
Hi Gerry
Dim T1 As Long
Dim T2 As Long
Dim T3 As Long
DoOEMButton(1011)'Zero A axis DRO
DoOEMButton(303)'MPG Velocity Only
T1 = GetOEMDRO(102) 'current encoder count
Code (" G01 A47 F900") 'move 47deg anticlockwise fast
While (IsMoving())
Sleep (100)
Wend
Code ("G01 A45 F200") 'move 2Deg clockwise slowly
While (IsMoving())
Sleep (100)
Wend
T2 = GetOEMDRO(102) 'new encoder count
T3 = T2 - T1
SetOEMDRO(1999,T3)'Put value T3 into Encoder DRO
Note without DoOEMButton(303) it always runs slow
cheers George
ps when I tried to attach file m1200 it told me 2 error one already exists rename"
so to load just remove (duplicate)
One other thing I have noticed is that if I go into
config ports and pins when I come out of it
and try turret it reverts back to slow feed
for first cycle.
George
Another strange thing
I have tried to remove the feed rate issue altogether
by changing the two code lines to G00 A47 and G00 A45 (rapid traverse)
and it is just the same slow on the first cycle fast on the rest !!!!!!!!
Where is the feed rate for G00 set?
The screen set I am using has feederate option G94 and G95
In one of my textbooks it says Fanuc type lathe controls normally use G98 and G99
Does anyone know what is correct for mach lathe?
Cheers George
George,
G00 - the max feedrate will be limited by the max Velocity setting in motor tuning
Note that an axis can be defined as linear and rotary.
G94 & G95 are correct for Mach3. See the manual for Mach's definition of G98 & G99. There are differences in the Gcode definitions
between manufactures and some manufacture Gcodes are specific to that manufacturer.
What version of Mach are you using?
What / who's screen set are you using?
May want to post you xml file.
Hi Rich
Mach version is R3.043.066
Please find attached xml and screen set
Got the screen somewhere on forums a couple of months ago
but can't see it listed now. Wanted to try it as it already had A DRO set up
only mod I have made to original is added extra encoder DRO.
However since your post I have tried using standard lathe screen and
problem is just the same.
What I have also tried is typing G01 A45 F900 directly into MDI line and this
works every time even after restarting mach or after viewing ports and pins
So then I tried writing a new shorter macro (without using cut and paste from previous macros)
consisting only of
DoOEMButton(1011)
Code("G01 A45 F900")
WhileIsMoving())
Sleep(100)
Wend
I then called this macro up direct from the MDI line and the problem is
exactly the same as before ie slow after start up then works fine
every subsequent attempt
Cheers George
Try going back to an older version like .062 or .057.
3.043.066 is known to be rather buggy,
Hi Gerry
Just the same unfortunately
cheers George
When mach 3 first loads up the feerate is set to zero.That is a safety feature. Try adding in a Fcall in the initiation string. Something like F100. The reason it is slow when you come out of config IS mach3 resets and that sets the Feedrate back to ZERO again (;-).
IF putting a f100 in the initiation string does not help then FORCE the Fcall it your macro by making a call. Code"F900" put it in before any action code, right after the last DIM call
Code"F900"
While Ismoving()
Wend
Doesn't it always default to 6ipm?
Hmm...thought it was 6 ipm also
I will need to check something in ver 62 as I have noticed, but ignored while testing my screen set, that at times that a slow feedrate
occurs, when, "I think" I have used the mpg and then want to rapid jog. So his use of the mpg in the script kind of rang a bell.
I may be all wet......but will try to check it out.
HI BR549
Thanks for the help.
When I did what you suggested the feed value does appear in the feed rate DRO but is not used
in either the fast or slow cycles. At the end of the cycle the feed DRO reverts back to this value.
However I have noticed something very strange.
When it does the fast cycle I thought it was following the feed rate in the macro. It is not.
It is actually following the value I have set up in motor tuning for axis A acceleration.
I have tried altering this for low to high values and it does appear to be using the acceleration value
as the feed rate.
Does anyone have any idea what could be causing this?
For information
The stepper driver I am using for the turret is a Leadshine DM422C
I have the steps per set to 93.333333333
the steps per rev of stepper is 1600
the turret gear ratio is 1:21
so (1600 x 21) / 360 = 93.3333333
also the manual states that t3 the pulse width should not be less than 7.5 us
(page 12 of manual)
I have tried the step pulse width at both 5 and 8 dir pulse width 5
with no change
I have tried several different acceleration values but for most of the time
I had it set at 900 which was the same feed rate value I had in my macro
and why I didn't realise it wasn't using that value
the velocity I have normally set to about 1/3 the accel value
let me know if you think this may be part of the problem?
cheers George
First I would NOT use the A axis for a turrent . It has special features that allow it to radius sync to the XYZ motion. I would use one of the other axis B C. You also need to start with a more normal setup I would start with VEL =200 and acel =20 as a test. THEN run the code and see how it responds.
ONCE you get it running smooth THEN you can play to find max vel and accel settings.
You could also be having trouble with the POKEYS ??
Just a thought, (;-)
Hi Guys
Sorry about the delay in responding but I have been working away for a few days.
Have done what you said ie changed axis over from A to B and it has made some improvement .
When the system is initialized it does start up at 6 (although my selected units are mm not inches)
Now when the turret moves in the fast cycle (either macro or MDI) it does follow the feed rate
(not the acceleration value in motor tuning as before) set in the code.
(or at least it seems to compared to the DRO I haven't actually timed it)
But I still have the problem that after start up coming out of ports and pins
it runs the first cycle slow (occasionally it will be two cycles)
This is true if the code is entered via the macro or MDI.
One thing I have noticed is that when the cycle is running on the slow
cycle the feed increase/ decrease buttons never work. When it is running in the
fast cycle some times the feed rate change buttons sometimes work!!
(but I haven't been able to spot the pattern why sometimes it does and sometimes
it doesn't)
I don't know what else to try.
Any suggestions would be greatly appreciated.
Cheers George
(ps I am contacting pokeys so see if the issue may stem from
pokeys but not holding my breath as I have tried without using
encoder readings or pokeys controlled button but just via MDI.
but we shall see what they say)
Hi Guys
Good news. I've cracked it. (well it seems to be working so far)
But I have absolutely no idea why it's working.
Stumbled across it by complete accident. I noticed that if I zeroed
the axis DRO immediately after start up or after coming out of ports and pins
it didn't go through the slow cycle.
What is strange is the first line of my macro zero's the DRO using
DoOEMButton(1012)
The button on the screen zeros the DRO using
Call SetDRO(4,0)
when I put the Call SetDRO(4,0) line at the start of the macro I don't get the slow cycle
The vb manual says SetDRO is just a legacy command and it's use is not recommended
So I tried putting an extra line of DoOEMButton(1012) but that didn't work
But at least I have a solution which seems to work so far.
If anyone has any has any theories why it is behaving like this I would love to hear them.
Cheers George
