Mach Discussion => VB and the development of wizards => Topic started by: PW8697 on September 01, 2015, 03:10:43 PM
Hey all,
Any one know how to set up a keyboard shortcut for starting the auto tool zero? Holding the touch off plate with my right hand and running the mouse to click the auto zero button is a pain. Would like to just be able to click Alt>L or Alt>Num Pad 1 or pretty much anything similar with my left hand.
Here is the current script for the button:
Rem
FeedCurrent = GetOemDRO(818) 'Get the current settings, OEM DROs (818)=Feedrate DRO
ZCurrent = GetOemDro(802) 'OEM DROs (802)=Z DRO
GageH = GetOEMDRO(1001) 'OEMDRO(1001)=Gage Block Height
ZNew = ZCurrent - 20 'probe down 20
Code "G90F10" 'slow feed rate to 10 IN/MIN
Rem Code "G4 P0.5" 'Pause 1 second to give time to position probe plate
Code "G31 Z" &ZNew
While IsMoving()
Sleep(10)
Wend
Call SetDro (2,GageH) 'DRO(2)=Z DRO
FinalMove = GageH + .25
Code "G0 Z" &FinalMove
Code "F" &FeedCurrent 'restore starting feed rate
Thanks, for any input.
Why not use the joypad plug-in and set a button combo to run the script?
Joypad? Don't want to add more hardware, cables, connections, failure points, etc.
Open the screenset with MachScreen and apply a hotkey {Alt_L} to the button then save and restart .
Using a roller ball mouse, lot faster and accurate with less hand movement needed, plus the buttons are larger. Will try MachScreen in the near future though.
