Mach Discussion => General Mach Discussion => Topic started by: krcmakina on August 11, 2015, 01:51:22 PM
Hi Everybody. i have a 12Nm Step Motor and i use to 16 Microstep ( 3200) and have a 1\5 gear Box and 40 Z tooth pinion how to i calculte pls write me formule...
All's calculator (linked here) should help http://www.machsupport.com/forum/index.php/topic,16315.0.html
You've not provided enough information, as we need to know either your Z screw pitch, or Z axis tooth spacing/pitch (you say pinion, so I'm going to assume you're using a rack?)
If you want to understand how to calculate the steps, have a read of this article - http://www.uk-cnc.com/2015/07/25/calculating-steps/
i dnt need Z axis dear X and Y axis enough for me calculation..
İ need Formule dear.. i have many documents about that but when i test .. step per is wrong :) so i wrote my specifaction.
You need to determine the Pitch Diameter of your 40 tooth pinion.
Russ
