Mach Discussion => VB and the development of wizards => Topic started by: MojsterMiha on August 03, 2015, 10:04:31 AM
Hi
Is there a possibility to store the data entered in a wizard under different names in order to be loaded back later and taken a small correction
(not only last entered data)?
I know that the G-code can be saved under different names, but if later I want to change something I have to write back all the parameters in the wizard and generate G-code again.
G-code is probably not possible to convert back into wizard DROs...????
Example:
Load wizard - Circular Pocket
Enter all necessary data...
Save entered data As....
Generate G-code
Load some saved data into Wizard (not only last one)
Make corrections...
Hope I was clear enough to get some advice... ;)
Most wizards have an option to save settings so they are there when you return. Some do it automatically on save and return
Yes, Iknow that.
But it is possible to save not only last one?
For example:
I fill in data for pocket nr.1 and generate G-code
Day after I fill in data for pocket nr.2.....
Day three....I want to call back wizard with data "Pocket nr.1"
It's possible something like this?
Sure it is possible, BUT you are going to have to rebuild and recode each wizard in order for it to do it (;-)
How I have to recode wizard? ???
I dont understand your suggestion.
Is there any command for save?
Where all data from wizard are saved?
