Mach Discussion => Mach SDK plugin questions and answers. => Topic started by: etet100 on August 02, 2015, 01:36:01 PM
Hi. Sorry for my poor english (i'm trying to do my best).
I'm working on USB motion controller. I noticed that after stopping program (Stop button) and starting it again (Cycle Start) some trajectory
vectors are lost. For example:
G2 X5 Y5 I5 J0
G1 Z6 F200
G3 X0 Y5 I0 J6
G1 X0 Y0 Z5 F1200
If i run program and then stop it almost immediately, mach stops filling trajectory buffer (GMoves Movements[0x1000]) after (for example)
70% of first arc. When i start it again it doesn't continue to generate first arc but go
straight to second or even third line of gcode.
I also noticed that it's probably correlated to "MainPlanner->ExBufferHi" value. The higher value it is, the more vectors are lost.
Could someone help me ? Thanks in advance.
Never use stop while the machine is moving. Use Feedhold instead. If you stop a program you need to be very careful how you restart. I always single step on a restart and watch carefully where the machine is versus where it need to go.
It look's like you are right. Issues with trajectory buffers are gone when i'm using feedhold.
Hovewer, in lpt mode i always used stop (or even emergency stop) and never experienced any problems. It was
very convinient. Is there any way to continue (automatically) correct path after stop or estop ?
I suspect that when using the printer port where Mach3 is generating every step it knows exactly where the stop happens as long as no steps are lost, like from a crash. However stopping with an external controller when the path has not completed leaves Mach 3 not knowing where the tool is. Using feed stop issues a command that tells the motion controller to bring the machine to a stop so position is maintained.
Thanks. In this case, further work on external pulse generator does not make sense. Using the parallel port is much more convinient.
