Mach Discussion => General Mach Discussion => Topic started by: ducati on July 16, 2015, 04:51:22 PM
I have my new 4th axis on my router
Besides indexing. Is there a way to use the axis to turn ?
Example... Using 1/2 end mill to traverse my long axis while spinning at
500 rpm.. Then proceed with a indexing type operation?
Without having different profile such as axis swap.
Would changing the general configure from angular accomplish this ?
So far at the midi line I am not getting it done.
A axis motor is a geared ac servo.
ducati:
The person to search out is member "simpson36".
He produces a 4th axis that indexes for regular machining, and also spins at high speed for turning. He also has vids of the operation on youtube.
It is not a trivial problem by any means.
John
