Mach Discussion => General Mach Discussion => Topic started by: bogger44 on April 29, 2007, 12:54:01 PM
I have a pre packaged table it was working ok I upgraded to the new nach 3 2 65 and it won't regen. toolpath past line 19 it says error plasma. o.o56 inch kerf 1/4
radius to end of arc differs from radius to start on line #19
and even before I have trouble scroling through the code if it screwed up to restart in the middle of a program still would'nt go past line 19.
I'm running a dyna cnc table with cand cnc thc mp 1000 sheetcam and mach.
Hi, Bogger44
Post your G-code file, Click on reply button there options to post your files there.
Under Config, General Config "Distance Mode and IJ Mode" the ABS and INC may be set wrong , change the IJ to opposite value.
In your G-code check near the top of your code for a G90, If there is a G91.1 or g90.1 on the same line, Edit and put it on it's own line.
G90, G91, G90.1, G91.1, Can't be on the same line.
Hope this Helps, Chip
g code is for touch n go floating plasma head
