Mach Discussion => General Mach Discussion => Topic started by: airbrush on May 31, 2015, 08:56:32 AM
I am just getting into mach and was wondering is there a way to have your machine go to an entered value?
Use MDI.
If you want to move to X5 Y5, just type the following into the MDI window:
G0 X5 Y5
When you hit enter, the machine will move to 5,5.
G0 is modal, so you don't need to type it for subsequent moves.
Just X5 Y5.
almost ready to cut with my machine and had one more question about this...
Mainly for zeroing...i have the 2010 screenset and will use the autozero to top of part...but my next question is I want to zero to a corner of my stock. I could just eyeball it pretty close but lets say i need it to be accurate....
So do i just move my tool over to an edge so it just touches against the side of the stock and then subtract the radius of the tool and type that in for my x and y using G0 ??
No, you can just type the tool radius into the DRO. Whether it's positive or negative depends on which side you're on, but I guess it would typically be negative.
Another option is to use the 2010 probing wizard. You can use another plate to probe against the edge, similar to auto zeroing the Z axis.
Sorry can you explain it a bit more...type it into which DRO? typing into the coordinates DRO doesnt move it.
What i've done so far is move the tool against the side of the part, zero it and then g0 x0.125 for example...same for y
is there another way of doing it??
p.s. i wish there was tooltips when i mouse over the icon buttons...i never remember what they all are and have open up the pdf to find out again.. :)
You don't need to move it.
If you have a 1/4" bit, and you jog up against the part, the center of the bit is at 0.125. You type that into the coordinate DRO, and the edge of the part becomes zero.
Unfortunately, Mach3 doesn't support tool tips. All the icons are listed in the manual.
hmm...okay...that just confuses me a bit...
I guess I would rather just type it into the MDI and actually move it and zero it so everything reads 0/0/0. Just makes it easier for me and my mind, seeing everything at zero. :)
since you're online right now...a quick question about settings.
I have everything setup now as far as config,softlimits etc...i click save settings from config..where is this file saved.
Or do i just copy my Mach3Mill.xml to backup everything (i'm running mach3mill to start mach)
I know this is a mach question but i have a feeling you would know :)
thx
If you do this, your not setting zero to the edge of the part. Your setting zero .125 away from the edge.
Unless you lift the tool, and move .125 over the edge, then zero it.
Your .xml is the file being saved. Yes, you can just copy it.
I suppose i could just use my move able touchplate to probe against the sides as well??
i'll have to read up on the manual again...does the edge probing function in the same way as Z. probes once, backs off and probes again?
thx
It can do it either once or twice. If the Slow Feedrate is 0, then it probes once. If you set a slow feedrate, it probes twice.
