General CNC Chat => Share Your GCode => Topic started by: Kenneth on May 21, 2015, 05:50:36 AM
below is the code i use to probe IDs. i like to know how to
use feed move. i want to be able to change the feed at the top instead
throughout the script. is this possible ? i tried Ffeed, but it laughed at me.
Thanks for any help !
NegMove = -10
PosMove = 10
Feed = 6
'probing = XY ID
'probe dia. = tapered till tip - - tip .104"
NegMove = -10
PosMove = 10
Code "G91 G31 F6 X"&NegMove 'X axis
While IsMoving()
Wend
SetOEMDRO(800,0)
Code "G00 X.2"
While IsMoving()
Wend
Code "G31 F6 X"&PosMove
While IsMoving()
Wend
Xdro = GetOEMDRO(800)
SetOEMDRO(800,Xdro/2)
While IsMoving()
Wend
Code "G90 G00 X0"
While IsMoving()
Wend
Code "G91 G31 F6 Y"&NegMove 'Y axis
While IsMoving()
Wend
SetOEMDRO(801,0)
Code "G00 Y.2"
While IsMoving()
Wend
Code "G31 F6 Y"&PosMove
While IsMoving()
Wend
Ydro = GetOEMDRO(801)
SetOEMDRO(801,Ydro/2)
Code "G90 G00 Y0"
End
Code "F10" 'slow down feedrate to 10 ipm
Thanks daniell,
if i put that at the beginning, after it hit G00 the rest of the
script will be in G00 mode. and i'm already going 6imp.
Thanks again
those aren't feed moves, but axis moves
Code "G4 P0.25" 'pause might pay to add pause in to you know its working properly and to give time for the Estop to be hit before the next move
i'm trying to change the feed at the top.
like ;
Feed = 6
then ;
Code "g31 F[Feed] X"&PosMove
that way i can change the feed in one area. is this possible ?
or even have two feeds
Feed1 = 6
Feed2 = 10
feed is Code "F"
look how the Code"F' is done in this code
Rem VBScript To probe In the z axis
If GetOemLED(801) Then 'check if English Units
If GetOemLED(16)<>0 Then 'Checks for machine coordinates
code "(Please change to working coordinates)"
Else
If GetOemLed (825) <> 0 Then 'check to see if the probe is already grounded or faulty
Code "(Z-Plate is grounded, check connection and try again)" 'this goes in the status bar if aplicable
Else
Code "G4 P1" 'pause 1 seconds to give time to position probe plate
PlateOffset = GetUserDRO(1151) 'get plate offset DRO
CurrentFeed = GetOemDRO(818) 'get the current feedrate to return to later
Rem Probe In the z direction
ZNew = GetDro(2) - 6 'probe move to current z - 6 inches
Code "G31Z" &ZNew
While IsMoving() 'wait for probe move to finish
Wend
ZNew = GetVar(2002) 'read the touch point
Code "G0 Z" &ZNew +.1 'move back +.1 to hit point incase there was overshoot +.1
While IsMoving ()
Wend
Rem End add lines
Code "F2" 'slow down feedrate to 2 ipm
ZNew = GetDro(2) - .25 'probe move to current z - .25 inches
Code "G31Z" &ZNew
Wend
Code "G0 Z" &ZNew 'move back to hit point incase there was overshoot
While IsMoving ()
Wend
If PlateOffset <> 0 Then
Call SetDro (2, PlateOffset) 'set the Z axis DRO to plate thickness
Code "G4 P0.25" 'pause for Dro to update.
'ZNew = PlateOffset + 3.6315 'calc retract
'Code "G0 Z" &ZNew 'put the Z retract height you want here
Code("G53G0Z-0.5") 'Z retract
While IsMoving ()
Wend
Code "(Z axis is now zeroed in English Units)" 'puts this message in the status bar
End If
Code "F" &CurrentFeed 'returns to prior feed rate
End If
End If
Else 'This portion of script is for Metric Native Units
Else
Code "F300" 'slow down feedrate to 300 mmpm
ZNew = GetDro(2) - 150 'probe move to current z - 150 mm
Code "G31Z" &ZNew
Wend
Code "G0 Z" &ZNew + 3 'move back + 3 mm to hit point incase there was overshoot + 3 mm
While IsMoving ()
Wend
Rem End add lines
Code "F50" 'slow down feedrate to 50 mmpm
ZNew = GetDro(2) - 6 'probe move to current z - 6 mm
Code "G31Z" &ZNew
Wend
While IsMoving ()
Wend
'ZNew = PlateOffset + 50 'calc retract
Code("G53G0Z-12")
While IsMoving ()
Wend
Code "(Z axis is now zeroed in Metric units)" 'puts this message in the status bar
End If
Code "F200"
Sleep 100
End If
End If
i understand. but to change your feed you'll have to go thru the script
and change each one. i understand that feed is modal and if i put
F6 at the top in would feed at 6 till it gets to G00 then ALL feeds will be G00
from there. "I" want to be able to change the feed in ONE place.
Is This Possible ?
like ;
Feed = 6
then ;
Feed1 = 6
Feed2 = 10
Feed1 = 6
Feed2 = 10
Code "G31 F" & Feed1 & " X" & PosMove
Code "G31 F" & Feed2 & " Y" & PosMove
do what TPS says
Thanks TPS.
but i tried the below and get script error.
Code "G31 F"&Feed & " X"&NegMove
your code:
my code:
Code "G31 F" & Feed & " X" & NegMove
i never figured out when you have to make spaces and when not, so i do them allways.
Thanks Daniell and TPS. this is what i got and works !
didn't know about spaces. Thanks TPS
'probing = XY ID
NegMove = -10
PosMove = 10
Feed = 6
Code "G31 F" & Feed & " X" & NegMove 'X axis
While IsMoving()
Wend
SetOEMDRO(800,0)
Code "G00 X.2"
While IsMoving()
Wend
Code "G31 F" & Feed & " X" & PosMove
While IsMoving()
Wend
While IsMoving()
Wend
Code "G00 X0"
While IsMoving()
Wend
Code "G31 F" & Feed & " Y" & NegMove 'Y axis
While IsMoving()
Wend
SetOEMDRO(801,0)
Code "G00 Y.2"
While IsMoving()
Wend
Code "G31 F" & Feed & " Y" & PosMove
While IsMoving()
Wend
Code "G00 Y0"
End
