Third party software and hardware support forums. => CS-Lab => Topic started by: octopus80 on May 01, 2015, 05:27:01 AM
Hello do somebody have any idea what the input freqencie is from this module I can't get 2hz as input, and for a turret I am missing pulse on it when the turret is turning.
I have the idea that it is not posible to read 2 inputs tougether.
I have done this whit e LeaveBoy 77 card and never have problems whit it.
benny
Maybe if you could explain a bit more what you are trying to do.
so it have only to read the inputs van de turret when it is moving and so it is not posible to read 2 inputs the same time.
so when the turret is moving you never know what place it gone stop.
I would think you should be able to read the two inputs at the same time. There will be a limitation of the update rate of Mach which is about 10Hz but other than that it should not be a problem.
Are you using a Brain or Macropump or Macro?
so I use a marco and the freqence is maybe 1Hz this can not be the problem, the Macro work whit other people only it work not good whit me.
Benny
Can you attach the macro please.
,Emco PC-Turn 50
'M6Start.M1s
'Input1 is an optical sensor used to count tool positions
'Input2 is from a microswitch used to determine tool 0 position
'OUTPUT6 drives the tool changer forward, de activating it allows the tool changer to rotate back against the ratchet pawl at low power and is the default
'Un comment the Open statement, various write# statements and the close# function to write a logfile for diagnostic purposes
'Close #1
'Open "M6start_log.txt" For Output As #1 'open a file to write logs to
NewTool = GetSelectedTool()
'NewTool = 2
'Write #1, "NewTool ", NewTool
OldTool = GetCurrentTool()
'Write #1, "OldTool ", OldTool
MaxToolNum = 6 'Max number of tools for the changer
CurrPos = OldTool
While (NewTool > MaxToolNum)
NewTool = Question ("Enter New Tool Number up to " & MaxToolNum)
Wend
'there is nothing to do so we just exit
If (NewTool = OldTool) And (NewTool > 0) Then
'Write #1, "New tool number is the same as old tool number. Nothing to do "
Exit Sub
End If
'If OldTool is 0 that means we dont know where the tool changer is currently positioned and need to reference to the microswitch for tool 1 position.
'need to establish tool 0 position from microswitch
If (OldTool = 0) Then
'Write #1, "Old tool number is zero, looking for reference position"
ActivateSignal(OUTPUT5)' Set toolchanger for full speed move
'Write #1, "Activated Output 5 to enable toolchanger motor"
ActivateSignal(OUTPUT6)' rotate tool changer forward
'Write #1, "Activated Output 6 to set forward direction"
While Not IsActive(INPUT2)
Wend
' Input 2 must Now be active so the microswitch has been triggered at position 1
CurrPos = 1
'Write #1, "Reference position found "
' Decide whether to just stop for the normal toolchange process
If ( CurrPos <> NewTool) Then
DeActivateSignal(OUTPUT6)
DeActivateSignal(OUTPUT5)
Else
' Or if we actuallly wanted tool 1 then stop and lock
DeActivateSignal(OUTPUT5) 'stop rotating forward, rotate backward now
'Write #1, "DeActivateSignal Output 5 toolchanger reverse "
SetCurrentTool(NewTool) 'sets up the current tool variable as the start point for a future tool change
'Write #1, "Setting CurrentTool to NewTool value ", NewTool
Sleep(2500) 'Allow a time interval for the toolchanger to settle back against the ratchet pawl
'Write #1, "Waited 2.5 seconds for toolchanger to lock "
DeActivateSignal(OUTPUT6) 'Disable toolchanger motor
'Write #1, "DeActivateSignal Output 6 toolchanger stop "
End If
End If
If (CurrPos <> NewTool) Then 'write the start condition to a variable
If IsActive(INPUT1) Then
PreviousSensorState = "Active"
Else
PreviousSensorState = "Inactive"
End If
'Write #1, "PreviousSensorState =", PreviousSensorState
'Write #1, "ActivateSignal Output 6 toolchanger go"
ActivateSignal(OUTPUT6) 'start rotating forward
'Write #1, "ActivateSignal Output 5 toolchanger forward "
While CurrPos <> NewTool
'Some logic to ensure that we only count on the leading edge of a slot in the toolchanger optical disk
Else
End If
'Write #1, "SensorState =", SensorState
If SensorState <> PreviousSensorState Then
If SensorState = "Inactive" Then
CurrPos = CurrPos +1
If CurrPos = 7 Then
CurrPos = 1
'Write #1, "CurrPos reached 7, reset to 1 "
End If
End If
'Write #1, "CurrPos =", CurrPos
PreviousSensorState = SensorState
End If
If CurrPos = NewTool Then
Sleep(1500) 'Allow a time interval for the toolchanger to settle back against the ratchet pawl
'Write #1, "Waited 1.5 seconds for toolchanger to lock "
End If
sleep(200) ' just slows the iterations down a bit
'Write #1, "Waited 0.2 second "
Wend
'Write #1, "should be job done "
'Close #1
End If
So the marco have to run on a Emco Turn 50 machine
Hi Benny,
i would try to use GetInBit(90, xx) insted of the IsActive(INPUT1)
statement, not sure witch one is faster.
it is also used in all CSMIO macro examples, maybe it helps.
i have used it in all my macros.
Thomas
I think what TPS says is the best way to try, it is the way I do the I/O with the CS-Lab controllers.
Note that when you do it that way you do not set up the I/O in Ports and Pins in Mach for these as if you do it will almost certainly cause a conflict.
Might also worthwhile taking the comments out to see what the log says.
Hi Benny,
any new info ?
Thomas
Hello Thomas
I have the turret working on the marco I have turn the encoder a litte bit so that there is a delay between the 2 signals.
and the major problem was that signal was triggering on the go down flank that I aspect that is was working on the going up flank.
greetings benny
