Mach Discussion => General Mach Discussion => Topic started by: ffulmer on April 29, 2015, 10:58:01 AM
I have lost my manual control. It will run a program and return to Z, but it will not respond to any manual input. Also I have no jog mode selection, I can't select Step or continues. Nothing lights up there. If I push the Z up, it will light up but the machine does not respond. I also have a usb port pulse generator and it does not work either. I have let the machine run programs cutting air and rebooted in the hope it would clear itself, but no luck. I need help!
Hi ffulmer,
Have you by any chance accidentally turned off the 'Jog ON/OFF' button on the main screen ??
