Mach Discussion => General Mach Discussion => Topic started by: Fred_evans on April 08, 2015, 01:17:49 PM
having now (after many months) a basic understanding of gcode,Mach3, Ports and pins etc and my machine
sort of running ok i decided to start again at page 1 of the manual and go through it step by step for about the
umpteenth time!!
This is the first of a few questions concerning some thing needing explaining
Quite a few guys have been helping and each with his own suggestions resulting in
some unknown differences being made to the setup and settings.
Machine setup Page 4.7 says i must tick the active low button on in ports and pins but i see my
setup has active low off ?? is this a serious issue?
What difference does it make?? anything i could detect when using the machine
all comments gratefully acknowledged
fred evans
Low is "off" or connected to common or ground, whereas high is on. Therefore a high signal would be at say 5v or in some cases 24v. For Mach3 it is usually 5v when high, and 0v when low.
That being the case, the tick box next to the signals, asks you to define whether the signal is "active" when it is high or when it is low.
Therefore, if you were to change a signal in ports and pins to "active low" from "active high" it would cease to function as intended since it would be off when the software was expecting it to be on, or vice versa.
So to answer your question, yes you would detect that something was no longer working when using the machine
Regards
David
Thanks David-- the machine is functioning OK so looks like I was worrying about nothing
I am at work at the moment and will check up tonight to see if I have perhaps
misinterpreted the tick or the cross-.
many thanks
LOW does NOT mean OFF and HIGH does NOT mean ON.
Low can be used to mean ON or OFF and High can be used to mean ON or OFF. That's exactly why the term ACTIVE(high or low) is used. If a system is set ACTIVE HIGH then it means just that, ACTIVE when HIGH. If on the other hand a system is set ACTIVE LOW then it means just that, ACTIVE when LOW. i.e. we use the term ACTIVE rather than ON because it's more meaningful and also helps to avoid the mistake of thinking HIGH is synonymous with ON and LOW is synonymous with OFF.
What change will you see if you were to change the active setting of something? It depends entirely on what that something is. If for example it's a direction pin then all that will happen is your axis will go the opposite way it did before. If on the other hand it's a spindle relay pin then it will be off when it should be on and vice versa. If however it's a step pin then it MAY make no difference whatsoever or it MAY stop your system from working properly.
i.e. Some active settings are down to you and how you've designed your system and changing them should have obvious and predictable results, a spindle relay for example. Others though should be set according to your hardware data sheets - a step pin for example.
I'm sorry, but I disagree. High is higher than low, either can be used as an active signal. It would be very confusing to have a high signal that is say 30v and a low signal that is 300v. I realise it is academic, but there you go. I think mr google would confirm my description, but in a far more lucid manner.
Sorry David - I'm not clear exactly what you're disagreeing with.
Can't argue with that. Exactly where did I suggest otherwise?
Exactly what I said.
I absolutely agree, exactly where did I suggest otherwise?
I stand by everything that I ACTUALLY said.
I must have been having a bad hair day. Bloody hormones!
Sorry
Sorry
;D ;D ;D
Anyway - back to Fred... (you still with us there Fred?)
Page 4.7 of what Fred?
You'd have to say which pin/function you're talking about to be able to answer this with any meaning.
Hello There
Page 4.7 of the mach3 turn manual-- sorry will be more precise next time
I will find the detail of the pin no tonight when I get home and put that in
regards
fred
OK Stirling now i got it
the reference is in section 4.6.3 and refers to the general settingh up of stepper motors.
the reference is as follows (typo's excluded)
"Stepper drive electronics usually use Active Lo configuration mach3 should be set up so these outputs are acrtive lo
..... " it goes on to say that inverted setting up will resuly in very rough and unreliable running
Yeah - this is a bit of a sweeping statement really because even if *most* drives were active low, that statement takes no account of the fact that your BOB (for example) *may* be inverting the signals before they even get to the drives.
The way to do this correctly of course is to simply follow what the manuals for your various hardware say.
However if your machine is running OK I wouldn't worry about it. You can always try swapping it and see if you notice any difference in the performance of your machine.
yes well everything seems to run OK so thanks for the input
What is a BOB?
thanks to everyone
fred
What is a BOB?
fred
break out board
