G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: homecockpitbuilder on April 19, 2007, 04:57:53 PM
Hello,
When i put a dxf file in lazycam (newest version oncl mach3) and export it to mach3 the file only has a little part of the complete drawing on the tooltable. It is show in a jellow striped box and when i run the router it stops when it's on the stripe. Is this a problem somone now how to fix that?
Kind regards:
Bas
Hey Bas,
Can you post a screen shot of your tool path screen and the g code file?
You can't load a spine in that rev... We hope to have that working soon :)
Brian
Hello,
Picture on this link:
http://www.homecockpitbuilder.com/mach3
Gcode on this file
http://www.homecockpitbuilder.com/gcode.tap
Hello Brain,
Can you explane what a spine means?
Regards Bas
Is Mach running as a demo, you can only process 1000 lines of code in the demo and your file is 5600 lines long.
Graham.
Ok Graham, thats the problem. Do i need only a licence for mach3 or also for lazycam?
regards Bas
The Mach3 licence covers the basic LazyCAM, if you want the pro version of LazyCAM its $50.00 more
Graham.
Hello Graham,
But when i only purcase mach3 its no problem to mill these file's.
regards Bas
No problem at all, it will work fine.
Ok then i purcase a licence
Regards Bas
Sorry it should have been a SPLINE :)
That is a line that has knot points making it bend in odd ways! We are looking into making them work but it takes time :(
Brian
