Mach Discussion => General Mach Discussion => Topic started by: Plan_B on March 29, 2015, 10:57:31 PM
Appologies if this is in the wrong forum...
I'm using Ger21's MACH3 2010 Screensets. The problem is with my X Axis, which is driven by 2 motors (one on each side of gantry - so X axis and A axis). A is the slave axis. I have been using the Auto Homing routine provided with the 2010 Screensets for a couple of years without any problems.
However, today... I hit the REF all home button and when it started to home my X Axis, the A motor didn't respond, but the X motor did. I tested it and the A Axis does work with both jogging and using G Code - Just not for Homing...
I checked the Config settings to make sure that the A Axis is still correctly configured for homing, and it is.
Anyone come across this one before? I haven't changed any settings and it's been working for years...
Please and Thanks!
Hey!
Nevermind, i figured it out :oP
Here's what the problem was for anyone else that might stumble here with the same issue....
It was just the polarity on the A Axis Home switch... I somehow ended up with the switch polarity toggled for A and not for X. So MACH 3 thought A was already on the switch...
Cheers!
Hi Plan_B,
Thanks for reporting back on the solution to the problem - this will no doubt help others who find themselves with a similar issue.
