Mach Discussion => General Mach Discussion => Topic started by: PSL on March 29, 2015, 03:39:36 PM
My computer crashed and I am trying to get everything up and running. I need to access the G code editor and change my system settings. I found what I need to change in the system but I am locked out. I cannot access the editor to change the system. Does anyone know how I can access the change? Any help would be great. Thank you.
I was able to get the gen config section taken care off. I am still unable to edit G codes. The program just regenerates itself and the green start cycle button lights up. Does anyone have any ideas on how I can edit G codes?
CONFIG>GENERAL CONFIG
Under Editor click the browse button and define where the editor exe file is located. ie;C:\notepad.exe
Save your settings.
Make sure when you use the editor that you save your changes to the gcode file.
This is what is in the editor C:\WINN\NOTEPAD.EXE. all caps and it is locked and I cannot edit it. Any suggestions? Thanks
Does the "browse" button work?
