General CNC Chat => Share Your GCode => Topic started by: jimbo1954 on March 25, 2015, 06:59:16 AM
Hi guys
i am in the process of building a new machine, this is 2meters by 1.8 meters, i have just set up the y axis and i am using rack and gear, i want the machine to run up and down a few hundred times to bed in the gears.
i have max'd out the motors , and i am getting a speed of 45 metres per minute without stalling or racking, of course i would never use this speed, but i just wanted to check to see how fast they will run at maximum, these are nema 23, 425 oz motors on a mod2 12 tooth gear and rack, direct , no gearbox. there seems to be plenty of torque in these motors,
what i want to do is start from the home position , y 0.00. and run it the full length of the bed, then return to the home position, pause for 2 secs so i can check the repeat position, then run back up at a slightly higher speed, and repeat about a couple of hundred times, this will help to bed in the gears and bearings, and also check for repeatability at the home position.
can anybody help me with the g gode for this please
thank you in anticipation
Jimbo
( code to run back and forth)
G90 G80 G40 G54 G21 G17 G50 G94 G64 (safety block)
M98 P1 L100 (RUN SUBROUTINE CODE 100 TIMES)
M30
o1
G1 Y1900 F45 ( YAXIS TRAVEL AT FEED RATE)
G1 Y0.0 (RETURN TO Y=0)
G4 P 2 ( PAUSE or can use M1 instead of G4)
M99 (RETURNS BACK TO THE )
Check config for the pause / dwell time so that it is seconds. You may want to use
M1 instead of G4 P2 , all you need to do is hit the cycle start each time, but gives you whatever time you wish to check indicator.
thanks rich for your speedy reply, is there anyway to increase the federate on each pass do you think??
best regards jimbo
feed rate
Think you would need to write a macro to do that.
Maybe someone can chime in and do one.
ok thanks
i didn't know if there is a possibility to create a variable for the feedrate then on each pass increase the variable by ...say 100. something like
feedrate = x
x= 1000
then on the next pass
x=x=100
x=x+100
Hi jimbo1954,
i think something like this should work:
#1 = 100 (start Speed)
M30
o1
#1 = [#1 +100] (increase Speed)
G1 Y1900 F[#1] ( YAXIS TRAVEL AT FEED RATE)
not tested yust try.
Thomas
works a treat , thank you for your help
regs
jimbo
