Mach Discussion => General Mach Discussion => Topic started by: notaxtrade on March 11, 2015, 05:54:59 PM
I am setting up a lathe with an Ethernet smoothstepper, connected to a C25 smoothstepper LPT breakout board, and it is wired to a C41 variable speed control, and then wired to my VFD. On the 'Motor Outputs' tab, X axis step=2, dir=3. My Spindle step=7, dir=8.
The bottom line is I cant get my spindle to turn if it is wired in this configuration. But if I put my step/dir wires from my spindle over to pins 2/3(which was the x axis), then I can jog the spindle with the up and down arrow keys. Any output pin that is assigned to the Spindle under the 'Motor Outputs' tab, it does not give step or PWM out of that pin anymore. If I assign the spindle to pin 2, then I will no longer get a step/pwm signal out of that pin when I try to turn the spindle on.
It sounds like it has to be a software/settings problem. Here is what I have: Under the 'Spindle Setup", I have set 'Motor Control' to have 'Use Spindle Motor Output' and 'PWM' is checked. Ive changed 'PWMBase Freq.' to all kinds on #s, and changed 'Minimum PWM'.
Here is my xml too.
Matt
Have you set the spindle up in the ESS Plugin Config?
