Mach Discussion => General Mach Discussion => Topic started by: camoit on February 13, 2015, 12:03:23 AM
Title: Unable to open ProbeDiag.dat Error=11
Post by: camoit on February 13, 2015, 12:03:23 AM
Please help.
Just like the title says I receive a
Unable to open ProbeDiag.dat Error=11 when starting up Mach3. It shows up for about 3 seconds at the start of the program then goes away. It happens when starting the profile I have set up.
I should first let you know I just got a new smothstepper ESS up and running. This error just started at the same time I tried to load the first G code into it. Before this it would JOG just fine and start the spindle and control the speed.
The moment I loaded G code it would kick out an error Art Code 8877. Then the program would stop working. Windows 7 machine just for the CNC
Can someone please give me some in site to this. I don't know why it would have started after trying to load a G code that was working on the system and Jogging just fine 30 seconds before.  ???
Title: Re: Unable to open ProbeDiag.dat Error=11
Post by: camoit on February 18, 2015, 11:18:44 PM
bump
Post by: Tarak on April 15, 2015, 04:45:56 PM
Hi camoit,
Did you find a solution, I've started having the same issue, it was working great and then all of a sudden the error started popping up?
Mine is Win7, USB smoothstepper and the latest Mach3 install.
Darc
Post by: aAndy on November 29, 2016, 01:07:41 PM
I had the same problem.   There was an access lock on the c:\Mach3\ProbeDiag.txt file and it prevented Mach3 from opening.
I deleted the c:\Mach3\ProbeDiag.txt file and Mach3 was able to open and run again.
Andy
Post by: Tarak on November 29, 2016, 02:39:30 PM
Thanks aAndy!
