Mach Discussion => General Mach Discussion => Topic started by: greg2fs on February 02, 2015, 03:47:58 AM
Hello, I would like to know if it is possible to say mach3 for exemple to add 0.01X to Z and 0.005Y, to correct a inclined plane.
Mach3 CAN do mods to the axis's through the "Formulas" function. If you are trying to correct a BAD ALIGNED table you will be MUCH better off to just FIX the machine as any thing else is just a crutch and will bite you before it is all over.
Just a thought, (;-) TP
Very simple, thank you !
