Mach Discussion => General Mach Discussion => Topic started by: makcnc on January 19, 2015, 12:53:00 PM
let's say that we have a tool that it changes its length or radius (grinding wheel ) so how cuold we modify these parameters also this happens while working
i guess by formula like
f(z)= z z>0
z-c*t z<0
c constant of consumption rate
t is working time
is this wright and how to write some thing like this in mach3 fomulas
No way that I know of to do it and it be correct. Wear is NOT a linear value. Best setup a probe and actually MEASURE the wear.
Just a thought, (;-) TP
i think first of all to measure the tool by auto tool zero every time then active the formula
the in-correction will come from the time spent in jug motion so if there is some way to isolate this time it will be very correct
