Mach Discussion => General Mach Discussion => Topic started by: NormB on December 23, 2014, 05:47:43 AM
I seem to have encountered a problem with the jog mode setup in Mach. when I start Mach3 the default is to step not continuous jog. This started when I purchased a pendant "remote control" I am not able to get Mach to default to continuous jog. Is there a way to do this?
Did you add a xhc hb04?
if so its the plug in for that hand control
email me and i will send you an updated one that fixes that
Gary
I too have an XHC HB04 (Wired-USB) pendant, but cannot get it to function. It finds the Mach3 and CNC machine but no data
on the LCD or functions work. It used to work when I first purchased it but I have been away from the CNC project for a while
now. I tried re-installing it but no luck. Not sure I have the correct .dll though?
Not much luck from http://www.cdxhctech.com/ either.
Any ideas how I can fix this. The hardware seems fine...just assume it's a software/plugin/.DLL issue.
Keith
I would try to reinstall or copy the dll file it might be corrupt.
