G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: geoff3881 on December 19, 2014, 04:26:25 AM
Title: Zero CAD to CAM
Post by: geoff3881 on December 19, 2014, 04:26:25 AM
I am trying to use Mach 3 to plot from a dxf file onto ply. As I have limited travel relative to the job size I am splitting the job into 4 segments and plotting 4 times moving the job each time within the machine travel area.
Its obviously necessary to get the 0-0 point correct for each segment  ie TR, BR, TL & BL
I thought this would be easy. I am using AutoCAD LT then LazyCAM to generate the G code.
The process works fine except for the zero problem.
As a trial, I have just created a 50mm dia circle with the centre at 0-0 on the dwg.
When this is processed and then loaded to Mach 3 the 0-0 point is not in the centre. It is at the corner of a rectangle of the dia size.
Why does it not carry over the 0-0 point from the drawing ?
What do I need to do to achieve this ?
Thanks Geoff
Title: Re: Zero CAD to CAM
Post by: RICH on December 19, 2014, 06:51:39 AM
Geoff,
Tick the box next to "As Drawn" located in the Setup Tab / Loading Option.
Post by: geoff3881 on December 19, 2014, 08:27:14 AM
Rich,
Many thanks. it now does exactly what I want.
Geoff
Post by: RICH on December 19, 2014, 06:36:12 PM
Merry Christmas........... ;)
Post by: geoff3881 on December 20, 2014, 03:00:33 AM
You to &- best wishes for 2015
Thanks again.
Geoff
