Third party software and hardware support forums. => CS-Lab => Topic started by: FredMazak on December 16, 2014, 04:58:21 PM
it is possible thread milling on the mill with cs lab and Mach3?
as in the link? https://www.youtube.com/watch?v=fm9L6uUkaFk&index=1&list=PLiy1Rbu2OLATkn71N0x1jPkUz6zLC3dnA (https://www.youtube.com/watch?v=fm9L6uUkaFk&index=1&list=PLiy1Rbu2OLATkn71N0x1jPkUz6zLC3dnA)
grtz
You will be able to threadmill no problem, it is not dependent on the control hardware you are using as it is simply a 3 axis move.
THX with encoder on the spindle axis.
and the addons http://www.machsupport.com/software/mill-wizard-beta/ (http://www.machsupport.com/software/mill-wizard-beta/)
For thread milling you do not require an encoder, all you are doing is commanding three axis to move at the same time, in other words x and y and Z all move in unison.
Mr Hood, thx
Is this also possible with a lathe X Z axis?
No, not thread milling as you require 3 axis simultaneous moves to do thread milling.
On a Lathe you can do single point threading. With the CSMIO/IP-A or IP-S that requires you have the Encoder module and a spindle encoder.
You can also do rigid tapping with the IP-S and IP-A (with Enc module and encoder)
