Mach Discussion => General Mach Discussion => Topic started by: Richard Evans on December 15, 2014, 11:11:59 AM
The old PC started to throw up a blue screen every now and again so I decided to swap everything to a newer one. I did it this way:
"What I do is install Mach3 on the target machine.
then Copy the C:\Mach directory and all its files over to a USB stick and then to the new machine C:\Mach directory." (as desribed by TP on the forum).
All settings have transfered perfectly as far as I can see.
Running Windows XP on both machines. Noew one is P4 2Gz.
However:
1. Keyboard jog controls don't work.
2. Spindle won't switch on manually.
A program will run, the machine works correctly, but the spindle doesn't start although the correct rpm appears in the window
Jog works correctly using a shuttle express
On the diagnostics screen, under 'Port 1 Pins current state', there are three green lights in positiions 4,5,6 from the left.
Nothing wrong with the machine, still works as before with the old PC.
Any ideas? Thanks!
Richard
Is your spindle being controlled by a different relay now?
is the keyboard plugged in ? ;)
Is the cable from the computer to the machine seated all the way?
1. No, no hardware changes.
2. Yes- but on checking it with notepad I have discovered it doesn't work!!!!! in fact, no keyboards are shown as installed so that issue is nothing to do with Mach.
3. Seems to be OK and works fine when swapped back to old PC
Thanks!! Very useful, at least one problem is identified.
Richard
OK... a USB keyboard works perfectly. So, that's one problem solved. But the spindle still doesn't go. I can hear the relay click in the control box when I press ' spindle on' but nothing else.
Richard
I've had that happen before when swapping computers with the spindle. I use a screen set that has a button for dust collection and vac bed. Try clicking one of those. They just control different relays on the board so you may find that your spindle is now your vac bed. So just change things around in general config. Why it does that I don't know.
All now fixed. This what I was advised on the Denford Forum:
"go into the bios and set the parallel port settings to EPP"
This works but I have no idea why!
Richard
