Mach Discussion => General Mach Discussion => Topic started by: lfjill on December 03, 2014, 07:55:41 PM
Mach3 doesn't ask me at startup (as before did) for the card installed
I went to Function Cfg's - reset card option in menu and it shows in a window: Next time startup the program will ask you...
Nevertheless it doesn't ask and the card is not recognized.
How can I solve this without reinstalling? I had motors and card configurated and tested and I don't want to begin again,
Is there a way it doesn't ask and it works with the card?
(xulifeng 250)
Thank you
L J
Sounds like you may not have the plugin installed.
I verified the plugins folder to get the surprise that it was blank. Then remembered that sometime I recovered the machine to a previous point respect the instalation of it some weeks ago.
I installed it and it seem not to have any problem.
Thank you very much.
Luis J
Is it a way to avoid being choosing the card each time the program starts and that it continue working well?
You can choose the box on the page that you click, it says something like Do not ask me again.
