Mach Discussion => General Mach Discussion => Topic started by: jokerper on October 09, 2014, 02:44:01 AM
Hi all people in here!
I think it is called a home switch.
I need a little help to understand how to make a tool change manually the best way.
My home switch:
(https://drive.google.com/file/d/0B3W8Oqg-Ke4jeEpvMV9BWm9Tbjg/view?usp=sharing)
Link:
https://drive.google.com/file/d/0B3W8Oqg-Ke4jeEpvMV9BWm9Tbjg/view?usp=sharing (https://drive.google.com/file/d/0B3W8Oqg-Ke4jeEpvMV9BWm9Tbjg/view?usp=sharing)
It got a wire into the spindle motor.
But how do I do a tool change and use this for setting the the correct new tool lenght/height after a manual tool change.
Any help on this question.
/Per
I think it is something like this but how do it work...
http://www.cncrouterparts.com/auto-z-touch-plate-instructions-p-291.html (http://www.cncrouterparts.com/auto-z-touch-plate-instructions-p-291.html)
Is it both with code and settings or how???
M6 t2 z - ("Safety zone and with space to make a tool change - z10.0000") and go back to the line before M6 how to and is this correct.
Where do the auto touch plate used in this picture - I dont understand..
Message( "Auto Zeroing..." )
If IsSuchSignal (22) Then
code "G31 Z-3 F20"
While IsMoving()
Wend
Call SetDRO( 2, 1.00 )
code "G1 Z1.5"
End If
What can I do with this code I have implemented. How can I work with this...
Do a search for auto tool height and you should find lots of info, here is one example which may help.
http://www.machsupport.com/forum/index.php/topic,10088.0.html
Hi, Hood
Thanks for your answer. I have been looking at the side before.
What I need is more specific how to use the auto tool height.
Let me try to explain what I meant.
When I start a router job, where there is a need of tool change or just setting the macihne running correct. I do not know how to do.
But When i have clampted my material. What to do is it now I use the auto tool height or is it between the tool change and how do
I do that.
measurement from a fixed point or just where the tool are ????
I dont know how or then I have to use the auto tool height or "home button" is it the same ??? ect. Maybe some good videos. I think most of them are use less for my beginner status and my small cheap cnc router.
Can you please help me...
/Per
Talk to Ger21, I am sure he sells a screenset (very reasonably priced) that does what you want.
Thanks...
