Mach Discussion => General Mach Discussion => Topic started by: kak on August 13, 2014, 10:51:00 AM
I have 4 axis foam cutter, but it´s not showing my gcode path on the display correct.
The left tower of the cutter is A and Z axis.
The right tower is X and Y axis.
Horizontal axis are A and X, vertical Z and Y.
Is it possible just to see one towers Gcode path on the display?
Because I have made some changes to the Gcode and I would like to see if it looks right before cutting.
There is a Foamcutter screen, 5 years old, but its not working when I load it.
But you can see what he is cutting on the display. Just to axis, one tower. My display is just some crossing lines and doesnt look like an airfoil.
Is there an option which axis I can see on the display?
http://www.machsupport.com/forum/index.php?topic=13546.0
