Mach Discussion => General Mach Discussion => Topic started by: B3030 on June 24, 2014, 12:40:26 PM
I've been using Mach3Mill with a router and mill for about 1.5 years. I typically use a simple CAD program to output a DXF file to Vectric Cut2D, Cut3D or Aspire, which spits out gcode for Mach3Mill.
I'm now configuring a Sherline lathe for CNC. I see the wizards in Mach3Turn, and will use them for simple parts to get started. I also see that I can string together a series of wizard outputs.
Is there a way to convert a CAD-generated profile into gcode that Mach3Turn will accept? As an example, how would I create gcode for a part with many complex concave and convex curves? I can easily create the profile in CAD, but creating it with the wizards seems like it would be much more difficult.
B3030
You would need CAM for that.
There is LazyTurn from Mach but I dont think it was ever really finished and I do not know how good it is.
There are a few reasonably priced CAM packages available for Lathes, the two I have used are Dolphin and BobCAD, of the two I prefer BobCAD but Dolphin does a good job.
Thanks for the info Hood.
I really hate the learning curve that comes with a broad sw package like Dolphin or BobCAD. I'm still overwhelmed with the Vectric sw. I hate to pile on another.
I'm looking at CAD2Lathe and CAD2gcode.
B3030
