Mach Discussion => General Mach Discussion => Topic started by: carbide on March 22, 2007, 03:46:14 PM
i am soon to be starting a project tp make a smalll cnc router/ mill and form the information i have with the plans i dont think i should have to many problems doing this .
but i have also thought why not convert a old Student colchester lathe i have to cnc and use mach 3,but a problem i have is i have no idea what size stepper motors to use on the 2 axis of the machine ,any tips on how to calculate what is needed would be good . ::)
I would think 916 oz/in at 2:1 reduction would be ample if you are going to be using ballscrews. Was going to be doing a student myself but a nice, hardly used Churchill CNC came along at the right price so the student is staying manual.
thanks alot,ill have to have a saerch see what info i can on some :D
Are you in the UK?
My lathe is similar size to a Student, I used a 400 oz/in on the X axis at 2:1, plenty of power. I used a 1200 oz/in on the Z axis at 1:1, it has enough power but my voltage is a bit low I think at 48 volts. I get a rapid of about 55 in per min at that. I did the 2:1 on the X axis and 1:1 on the Z so that with 10X microstepping and .200" ballscrews I would have .0001" resolution on both axis, the X needing twice the normal because of the diameter change. Just remember, the Z axis needs at least 3 times the power that the X does, much more weight to accelerate there.
