Mach Discussion => General Mach Discussion => Topic started by: Confused1 on May 29, 2014, 01:48:04 AM
Hi
I’m new here & new to CNC machines. Some background:
• I have a homemade machine. The working area is approx. 2’ x 4’ with 4” of travel on the Z axis.
• I have ½” lead screws on all axes – 2 to 1.
• The motors are NEMA 24 for the Y & Z axis; NEMA 34 for the X axis.
• I am using Windows XP with Mach 3
• The projects I am trying to cut were done on Cut 2D 1.5.
• Right now I’m just doing simple tests such as a name plate where the letters are cut out by the machine.
• The material I’m cutting is wood – 5” x 10”, 5/8” thick is typical. I use the bottom left corner as my X,Y origin point.
The problem I’m having is that when I start cutting the project, the CNC machine lowers the tool all the way through the work piece and actually into the table (about .02”) & stays there until it reaches the start point of the 1st letter to be cut. The machine then raises the tool & starts cutting the letters. However, it regularly lowers the tool below the bottom of the cut I want to make. It does this in between letters. Then, at the end of the cut, the bit gets lowered all the way through the piece & it stays there until it reaches the start point.
The physical set up of my machine looks OK. I’m wondering if I set up Mach 3 wrong.
Hope this is the right place to post this. If not, any suggestions as to where I can get help would be appreciated.
Bob
Hi Bob,
My guess is that you have your settings wrong in Cut2D.
If you .zip and attach your GCode file I will check it here and see if it is OK.
Tweakie,
Thanks for looking at this! Zip file is attached.
Bob
Hi Bob,
Your GCode plays out fine here so nothing wrong with your Cut2D settings as I had suspected.
Perhaps look in Mach3 / Config / Safe_Z Setup – if the Allow Safe_Z Moves box is checked then uncheck it (or alternately if you wish to use Safe_Z then make sure all the settings are correct).
Perhaps stupid suggestion but is your machine’s Z axis configured correctly with Z0.200 moving the spindle upwards and Z-0.0500 moving it downwards ?
Tweakie,
Thanks for your help with my problem.
Your suggestion was not stupid; I has my Z Axis set up incorrectly. It just took me a while to see & fix it! My machine seems to be running fine now.
Again thanks for your help.
Bob
Hi Bob,
I am pleased to hear that you have resolved the problem ;)
