Mach Discussion => General Mach Discussion => Topic started by: Segrest on March 17, 2007, 01:43:31 PM
Hello Everyone,
I am working on a small project on my ShopTask machine using Mach3. After making several duplicates of the same part I noticed that my end mill wasn't cutting as clean as it had on the first part and that my tollerances were starting to drift out of spec. I replaced the end mill with one that had been resharpened and the cuts looked much better. Then is discovered that my parts were really out of tollerance. For example I milled out a round hole that is supposed to be 1.757 inches in diameter and it only measures 1.744 inches. I checked several other different dimensions and the results tell me that my end mill is under size by about 0.0065.
When I look at the tool table dialog in Mach3 there is a field named "Diameter Wear".
If I enter a value in the Diameter Wear column for my tool, will it cause Mach3 to correct for my under sized tool?
If this is the case, what value should I put into this field?
Bob
I don't think diameter wear does anything. But, if you program using cutter comp (G41/G42) the tool diameter in the table will be used to calculate you toolpaths.
