Mach Discussion => General Mach Discussion => Topic started by: djk on April 17, 2014, 04:05:36 PM
Hi
I had a old Demo mach3, every thing worked well. I updated and brought a license, now I have a problem with the wizards- cut circle - kiran.
First thing, when I have X center and Y center 0 the center is off to the side and the finish pass is off center. Second thing is circle Dia and tool Dia are wrong. I have to change these to circle radius and tool radius to get the right size circle.
If some one can help.
Thanks David
(http://)
You have the IJ mode set wrong, go to General Config and change it to Inc.
Thanks Hood everything is working fine now.
David
