Mach Discussion => General Mach Discussion => Topic started by: SirFinland on March 10, 2014, 07:13:34 AM
Hi!
How can I chnge the height in Mach3?
I'm using Vcarve and it's allways 25.4 for the Z How can I change that so it wont drill straiht in to the board?
Thanks!
You need to change it in V-Carve Pro.
As ger21 said, you need to change your settings in VCarve.
In the toolpaths tab, the first icon is "Setup material and rapid gaps". You can change the retract height there.
