Mach Discussion => FAQs => Topic started by: dante on February 06, 2014, 08:24:10 AM
greetings,
i just started my internship on a company and they have just bought a emco 120 turn with mach 3 on it. i have been trying to make this machine work and so far i have succeeded considering i dont know nothing about how this machine works and neither do they. right now i am trying to make a product manually with jog function so that i can record it with the jcode plugin so that the next time i can simply run the program.
unfortunately i have alot of problems regarding the DRO screen. it shows the wrongg measuremen information t compared with the movements i make. as example: when i move 1 mm with the turret the DROs shows that i have moved around 4mms which makes it very hard to measure the length of the movements.
is there any possible way to solve this problem so that the movements are correct on the DRO?
kindest regards
Do you have a manual for the emco120? Post it.
Have you had a look at the Mach lathe manual? Suggest you start reading it.
You need to make sure that Mach is configured correctly and for the way you wish to work and for that machine.
thank you for the quick reply. i have read the manual again and i came into understanding that my motor tuning settings are incorrect. yet i am not sure what are the right settings are for the velocity, acceleration and steps per unit. is there a common setting for those?
thx
i see that mach3miller has a set steps per unit function on the settings tab. does mach turn have this function aswell?
You will need to calculate them based on the your specifc machine.
I am not familar with the 120 Turn.
Do you have a manual for the it? If so post it. If not have your company buy / purchase / find one for it.
You will find calculator's in Member's Members Doc's and there are instructions in the manual how to calculate the steps per unit.
Velocity and acceleration are done by trial and error.
thank you for the information! unfortunately i dont have the manual for the machine but i will look for it and post it when i find it :)
kindest regards,
dan
Are the motors steppers or servo's?
What is the pitch of the x & z ball screws?
What gear ratio , if any, is there on each axis?
i am not quite sure how to find those settings by myself but i blive i found the correct data on yahoo answers
quote: " 100 tooth, 2mm pitch on the stepper. 50 tooth 2mm pitch on the 5mm ballscrew. The belts .. gates mxl "
