Mach Discussion => General Mach Discussion => Topic started by: JMF on January 23, 2014, 10:57:43 PM
Title: What files exactly ?
Post by: JMF on January 23, 2014, 10:57:43 PM
If I develop screens for Mach3 and have made my custom changes in Mach3 (setup info, inputs, outputs etc. etc.) what files do I need to save if I had to reinstall Mach3 ?
I'm thinking,
First I need my XML file
Second I need to save my .SET file
Third I need to save the HiddenScript.m1s file if I've made changes to Mach3 pushbutton scripts.
Fourth I need to save all bitmaps I've used in my custom screens.
Is this pretty much all I need to get a fresh copy of Mach3 back to my setup ?
Or am I still missing something ?
       John
Title: Re: What files exactly ?
Post by: ger21 on January 23, 2014, 11:42:12 PM
You don't need to save Hiddenscript.m1s
It's just a placeholder file used when editing scripts. The scripts themselves are saved in the .set file
You usually just need the bitmaps, .set file and .xml
If you have any M code macros or Brains, you'll need to save them to. If you've modified any of the default macros (M6Start.m1s), you'll want to save them too.
Post by: JMF on January 24, 2014, 01:06:43 AM
Thanks ger21 !
Just wanted to know which files to save in case I have to restore my setup.
           John
