Third party software and hardware support forums. => Newfangled Mill Wizard => Topic started by: jkurtis on January 20, 2014, 09:58:28 PM
Hi Ron-
I have tried to make a rectangle pocket and a circle pocket (first cuts I have ever made on new DIY mill). The rectangle was supposed to be 5" by 1" with the origin at X=2.5" and y=-0.5". The circle was supposed to be 1" in diameter.
The circle came out correctly sized and located. The rectangle was correctly located, but was too long (5.13") and wide (1.14"). I set this up for a 5/16" end mill and have made certain that this was the end mill that was used.
At first, i thought this may have something to do with "cutter compensation", based on my cursory knowledge of these G codes. After looking at the code, I do not think this is the problem (can't find these codes in the NFS mill wizard output).
I append the NFS output below.
As this is truly my very first attempt to machine anything, I expect I am doing something wrong....
thx for any help,
best,
jake
Please attach the job file as that gives me all the input parameters. Also what version are you running? I know I fixed some rectangle size issues a while ago, but I think they were related to minimum size.
Hi- I discarded the original job file, but here is the re-created version. It gives the same g-code as the original, and Mill Wizard auto-repopulated the pocket parameters from the last use (very nice feature !).
thx for looking at this.
best
jake
Ok, Im a bit off my mark right now, spent another day in the hospital, thats about 10 since Dec 1. All for damn kidney stones. I should be back to as normal as I get in a day or two. I assure you this will be my first effort when Im back
Hi Ron,
Hope you get back to 'normal' real soon !
Wishing you all the best .... and hoping to see you again in April.
Kind regards,
Russ :)
Oh my. Pls take your time. I'm just playing at this point with setting up new mill. Feel better. Best
Jake
Sent from my iPhone using Tapatalk
Sorry, forgot to mention I'm using v1.0.13.
Sent from my iPad using Tapatalk (http://tapatalk.com/m?id=1)
Is your mill accurately calibrated for steps per unit? this code seems to me work as expected. I dont see anything going outside the 5x1 area.
