Mach Discussion => General Mach Discussion => Topic started by: vertcnc on January 09, 2014, 11:17:40 PM
I would like to control the GS3 via Modbus. I have the rs485 connected and appears Modbus communicates without error. I having a problem understanding the settings for start reg and # of registers. it appears I can read on the input side on start reg 0 I can read 7 registers. How should the output be setup to control spindle. I also would like to map the inputs to User DRO's to display RPM, AMPS, Freq. if possible.
http://www.automationdirect.com/static/manuals/gs3m/ch5.pdf (http://www.automationdirect.com/static/manuals/gs3m/ch5.pdf)
Can I do this with some VB scripts or is a Brain required.
Ok, I figured out the address for reading the drive status and displaying the data to userdro's. Still can figure out what address for output. Any help would be appreciated.
