Mach Discussion => General Mach Discussion => Topic started by: bankshot on December 25, 2013, 05:53:25 AM
on my older programs, no problem. some that i have written recently come up and run fine but the part on screen is way to small. havent figured out if i did something or a setting is wrong.
larry
You will really need to attach your xml and some code, both old and new code so we can see what you mean.
thanks hood. my computer is in the shop with no printer nor internet access so im not sure how ill do that but ill think about it...btw, i wrote a program today and display is fine..probably something i unknowingly did
If you mean the tool path is small, try zeroing the DROs before loading a program.
Happy New Year All,
John Champlain
thanks pice ill check that
