Mach Discussion => General Mach Discussion => Topic started by: Dallassignco on December 09, 2013, 01:46:19 PM
Hello; I was told, since I don't have any more input pins available, I could connect my auto tool zero plate "in parallel" with the A axis. As a test, shouldn't I be able to take the wires leading to my input limit switch (on A axis), then attach them to my alligator clips/ assign ports and pins correctly - and it should then work (providing I have the correct script). Is this correct? Thanks
It would depend how you have the switches set up NC or NO.
Thank you for the reply
