Third party software and hardware support forums. => SmoothStepper USB => Topic started by: mechfx on November 26, 2013, 10:35:04 PM
After a lot of messing around I have discovered through the SS forum that THC is NOT supported with the USB-parallel port card.
The THC board I am using is getting the signal all the way back to MAch3 OK but there is no connection between the Up and Down indication on screen and the signal to the Z-axis to raise and lower.
Can anyone think of a macro or subroutine that could "read" the signal that the on screen indicator is reading and link it somehow to a hotkey or similar to allow mach3 to raise/lower the Z axis on the run ? I am no expert in this area
I already have a hotkey set up on the pendant that can drive the z-axis on the run.
thanks
Art
Hi, I ran into the same problem (USB Smoothstepper does not support THC).... I am sorry to say I have no solution for your problem what I did is that i got the
Compact THC SD ( Proma - Elektronika Step/Dir Generator ) Torch Hight Controller.
It works fine since it does not use the software for hight control
My problem is that I now want to use OXI/Acetelene cutter and need to manually control the hight .... How did you set the hotkey to drive the z axis on the run? please help
Hallo, hatte dasselbe Problem mit einem XHC Mach4 MK6 USB Motion Controller und externem THC. Ich habe das Problem gelöst indem ich die Eingänge des Motion Controllers in der Konfiguration/Control/Eingänge mit Jog Z+ und Jog Z- verknüpft habe.
Software Mach4 4.2.0.4612 Build
Hello, had the same problem with an XHC Mach4 MK6 USB Motion Controller and external THC. I solved the problem by linking the inputs of the motion controller in Configuration/Control/Inputs with Jog Z+ and Jog Z-.
Software Mach4 4.2.0.4612 build
