Mach Discussion => Mach3 under Vista => Topic started by: mk22000 on November 14, 2013, 02:37:12 PM
Hello everyone I am new at cnc world and I am so confused.i set up my cnc and a pc which run a fresh format of win7.the problem is that at first I run my cnc ok and did some cuts,but after a few days my hard disk had problem and I buy a new one,so I setup win 7 again and mach 3 but this time after installing the driver test when I try to open mach my computer crash to blue screen and restart itself.when I delete driver test it open normally but no axis moving?sorry about bad English,what do you thing?
I have the same problem. My computer crashes and restarts when I open Mach3. This started happening when I run the driver test. At initial install, I can open Mach3 with no problem, but I do not have motor controls. After running driver test, the driver got installed, and the blue screen of death started happening whenever I open Mach3. This still happens even after I installed the special driver. I am running Windows 7 32bit on an old computer (3Ghz Pentium D, 2gb ram). I really hope someone can help me. I cannot find any solution to this problem anywhere. Please help. Thank you.
Hi Guys,
Welcome to the forum.
Sounds to me as though your PC is not up to the task.
Perhaps installing WinXP as the operating system may improve the situation.
Same problem. Windows 7 32 bit. Everytime I try to run Mach3 it just reboots my computer. The only Mach program that will run is lazy cam.
Does anyone have a better solution than buying and installing Windows XP? I thought Mach3 ran on Windows 7 32 bit?
It used to, until Microsoft updated Windows 7.
Try this.
http://www.machsupport.com/forum/index.php/topic,38269.0.html
i have the same problem with win7 32 and a Panasonic cf 19 i just bought for the workshop....if i buy win xp and put that on the laptop will that sort it.?
sounds like the security updates from Microsoft to Windows7.
http://forum.machsupport.com/forum/index.php/topic,38269.0.html (http://forum.machsupport.com/forum/index.php/topic,38269.0.html)
Thankyou worked a treat
I kinda remember that there is a driver that mach uses and i seen a video of a guy showing it giving him a blue screen and by going into a mach folder and replacing it with another driver and rebooting it will correct the problem watch this video around 3:48 https://www.youtube.com/watch?v=KiCLoQmuJ3g
