Mach Discussion => General Mach Discussion => Topic started by: Lloyd on November 09, 2013, 03:52:30 PM
Is there a lower cost alternative Digital Step drive that works like the Gecko G540? I understand though you get what you pay for. Thanks!
Lloyd,
Depending u[on your requirements, this one is hard to beat, if you know how to solder. http://www.hobbycnc.com/
John Champlain
There are several cheaper drives but none that offer the value for the money spent. Most other stepper drives use off the shelf stepper driver chips that offer only a fraction of the performance of the G250 drives inside the G540. Then if you add in all the ancillaries to get the same feature set: optical isolation, two high current relay drivers, VFD output, charge pump circuit you will spend almost as much money and get lower performance. I have a lot of customers who started with the cheaper boards and when they finally moved up to a G540 (because the cheaper board was not satisfactory or blew up) they are shocked by the performance difference.
