G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: FalconX50 on October 09, 2013, 12:41:16 AM
Title: Help a newbe! archs not working!
Post by: FalconX50 on October 09, 2013, 12:41:16 AM
Hello everyone,
I am new to all of this CNC stuff but..., I have a SiegX3 converted and running very well. X & Y @ 25ipm and Z @ 20. All is smooth and accurate. Could run faster but not yet.
First; my system: Gigabyte MOBO, AMD FX64 2.8GHz, 2GBmem, running XP sp2.
I use TurboCAD Pro16 with the CAM Pluggin. The default CNC setting is FAUNC.
I can mill all kinds of lines or paths or text with no hiccups.
My problem: I am trying to mill a path and when TurboCAD converts everything to G-Code the pictures are different between what TurboCAD does and what MACH3 does.
I am sure it is a settings thing but I don't know enough about G-Code to understand what is going on. Below is the code and when it shows in MACH3 there are extra circles
running around the origin that shouldn't be there and, the archs aren't right either they are straight lines instead.
% ( MYAPP01 )
N1 O1
N2 G20
N3 G00 G17 G40 G49 G90 Z0.5
( TOOL COMMENT IS NOT FOUND )
N4 T2 M06
N5 G00 G90 G54 X3.7456 Y3.408 S1000 M03
N6 G43 H2 Z0.25 M08
( OPERATION NAME = OPERATION-1 )
N7 F12.
( MILLING POCKET )
N8 G01 X3.7456 Y3.408 Z-0.04
N9 X3.7948 I-0.1659 J0.1871 Y3.4676 Z-0.04
N10 X3.8432 I0.2127 J0.1314 Y3.4106 Z-0.04
N11 X3.7926 I0.1473 J-0.202 Y3.3613 Z-0.04
N12 X3.7456 I-0.1981 J-0.1525 Y3.408 Z-0.04
N13 G01 X3.6701 Y3.3084 Z-0.04
N14 X3.529 I-0.0756 J-0.0996 Y3.3153 Z-0.04
N15 G01 X3.5273 Y3.3142 Z-0.04
N16 G01 X3.516 Y3.3166 Z-0.04
N17 G01 X3.509 Y3.3243 Z-0.04
N18 G01 X3.5057 Y3.3312 Z-0.04
N19 G01 X3.4993 Y3.354 Z-0.04
N20 G01 X3.4939 Y3.3861 Z-0.04
N21 G01 X3.4939 Y3.4171 Z-0.04
N22 G01 X3.4987 Y3.4507 Z-0.04
N23 G01 X3.5083 Y3.4784 Z-0.04
N24 G01 X3.509 Y3.4795 Z-0.04
N25 G01 X3.5135 Y3.4826 Z-0.04
N26 G01 X3.5191 Y3.4838 Z-0.04
N27 G01 X3.5234 Y3.4835 Z-0.04
N28 X3.7041 I0.0563 J0.1116 Y3.6078 Z-0.04
N29 G01 X3.7016 Y3.632 Z-0.04
N30 G01 X3.7027 Y3.6414 Z-0.04
N31 G01 X3.7062 Y3.6454 Z-0.04
N32 G01 X3.7152 Y3.6499 Z-0.04
N33 G01 X3.7385 Y3.6578 Z-0.04
N34 G01 X3.7554 Y3.6602 Z-0.04
N35 G01 X3.7942 Y3.6617 Z-0.04
N36 G01 X3.825 Y3.6602 Z-0.04
N37 G01 X3.8499 Y3.6572 Z-0.04
N38 G01 X3.8714 Y3.6505 Z-0.04
N39 G01 X3.8775 Y3.6473 Z-0.04
N40 G01 X3.881 Y3.6437 Z-0.04
N41 G01 X3.8834 Y3.6207 Z-0.04
N42 G01 X3.8827 Y3.6051 Z-0.04
N43 X4.0539 I0.1249 J-0.006 Y3.483 Z-0.04
N44 G01 X4.0543 Y3.4831 Z-0.04
N45 G01 X4.0598 Y3.4832 Z-0.04
N46 G01 X4.0719 Y3.4814 Z-0.04
N47 G01 X4.0729 Y3.481 Z-0.04
N48 G01 X4.0764 Y3.4756 Z-0.04
N49 G01 X4.0804 Y3.4667 Z-0.04
N50 G01 X4.0843 Y3.4528 Z-0.04
N51 G01 X4.0879 Y3.4264 Z-0.04
N52 G01 X4.0896 Y3.4015 Z-0.04
N53 G01 X4.0886 Y3.3746 Z-0.04
N54 G01 X4.0856 Y3.3515 Z-0.04
N55 G01 X4.0792 Y3.3328 Z-0.04
N56 G01 X4.0736 Y3.3232 Z-0.04
N57 G01 X4.0698 Y3.3189 Z-0.04
N58 G01 X4.0645 Y3.316 Z-0.04
N59 G01 X4.0569 Y3.3149 Z-0.04
N60 G01 X4.0491 Y3.319 Z-0.04
N61 X3.8657 I-0.0585 J-0.1105 Y3.2138 Z-0.04
N62 G01 X3.8655 Y3.2102 Z-0.04
N63 G01 X3.8618 Y3.2002 Z-0.04
N64 G01 X3.8556 Y3.1897 Z-0.04
N65 G01 X3.837 Y3.1692 Z-0.04
N66 G01 X3.8129 Y3.1486 Z-0.04
N67 G01 X3.7935 Y3.136 Z-0.04
N68 G01 X3.7907 Y3.1344 Z-0.04
N69 G01 X3.7677 Y3.1502 Z-0.04
N70 G01 X3.7473 Y3.169 Z-0.04
N71 G01 X3.7309 Y3.1869 Z-0.04
N72 G01 X3.7234 Y3.1995 Z-0.04
N73 G01 X3.7195 Y3.2119 Z-0.04
N74 X3.6701 I-0.125 J-0.0031 Y3.3084 Z-0.04
N75 I0.0378 J0.0498 G02 X3.6581 Y3.396 Z-0.04
N76 G01 X3.6581 Y3.396 Z0.25
N77 M05
N78 G91 G00 G28 Z0. M09
N79 G28 X0. Y0.
N80 M30
Title: Re: Help a newbe! archs not working!
Post by: Graham Waterworth on October 09, 2013, 07:22:12 AM
It looks like you need to look at the post as the code is not correct you have no G02/G03 on the lines N9 - N12, N14, 28,43,61,74 and 75
Post by: FalconX50 on October 09, 2013, 08:16:32 PM
Um so I need to add the code G02 to those lines with the I & j cords?, So if I understand I need to figure out where in the TurboCAD/CAM program settings that will set that up automatically. Does anyone here use TurboCAD/CAM and know where I can configure that? If I do more files that are a little more complicated I think it would be a pain to rewrite all the G-Code all of the time.
Post by: Graham Waterworth on October 11, 2013, 05:18:00 AM
Try using a different post for any Fanuc, Hass, Secos or Yasnak control model that is listed and see if it gives you similar looking gcode but with the correct G02/3 in the code.
Then you can compare the 2 posts and see why the Fanuc is not putting them in.
